Third brake light/rear window defroster wiring mixup help
I just got my car back from the body shop and the third bake light isn’t working unless you pull the **** for the rear window defroster which then lights up the third brake light. It seems the shop mixed up the wires. Can anyone give me some assistance to correct this? Why does the wiring up there look like? I cannot get back to the shop for a while to have them do it so I need to correct it.
Here are screenshots of the wiring diagram that lists the wire colors and the shared wiring harness plug X27 and its pin positions both devices use. If the shop inadvertently mixed up the pins in the plug it most likely can be pried apart and the pins repositioned in their correct places.
Andy
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/402x230/image_e1bbcc8d228a06e1c9520783e651932d08923338.png)
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/358x395/image_bd9169aea25de68764d81d24014b70fa7d15f8e7.png)
This is perfect thank you!
