First serious question!!
Ok,
in my car the stwich for the rear screen demister does'nt seem to be working properly. What happens is when you pull it out, it won't stay out - it returns to its 'off' position all the time. So I imagin its broken. Where could I get one of these and is it hard to replace?
Thanks.
Thanks.
Correct,
On the 993, when you pull the "momentary" switch, it trips a timed relay. I would investigate the vitality of the relay. The switch is likely healthy.
-WAM
-WAM
Keeper of the Truth
William is correct. When you pull the switch, the rear defroster relay is activated and the switch returns to the "off" position. However, the light inside the switch remains on for the duration of the defroster function.
The original poster might not need this but surely someone searching the archives will benefit. Thanks for your contribution.
