993 Forum 1995-1998
1995 lwfw ?
Old Sep 16, 2019 | 08:01 PM
Paseb's Avatar
Paseb
Default 1995 lwfw ?
Adding a lightweight flywheel on a 1995? Is it doable?
If adding steve wong chip at the same time, will it fix the stalling issue?
Thinking already about winter projects here in mtl as the snow will arrive early december.
Lwfw and clutch
Steve wong chip
Regearing transmission
Thx for help
Old Sep 16, 2019 | 08:05 PM
AOW162435's Avatar
AOW162435
Seared
Have you driven a 993 with a LWFW? While the ability to rev the engine faster is certainly appealing, the bucket-of-bolts sound is not. At least to me.
I think Steve has a chip that addresses the stalling issue.
Andreas
Old Sep 16, 2019 | 08:09 PM
P-daddy's Avatar
P-daddy
I had a 95 993 and a 964 with LFW. Both had Wong chip. Lucky me no “bucket o bolts” at idle nor stalling.
Steve has different chipset for your particular needs ie Stall Fix only, Stall Fix and 93 octane, cat delete, etc
Old Sep 16, 2019 | 08:16 PM
Paseb's Avatar
Paseb
My 993 has fister 3 and catbypass
My cayenne has cat bypass
My race car is straight pipe
Im ok with all funky sounds lol
Old Sep 16, 2019 | 08:18 PM
Paseb's Avatar
Paseb
Okk so wong chip is a most then
Is there a good site to purchase the combo?
I emailed darin already
Paseb's Avatar
Paseb
Andreas
I haven't
There ls not much 993 in montreal
Old Sep 16, 2019 | 08:34 PM
P-daddy's Avatar
P-daddy
https://www.911chips.com/products.html
Old Sep 16, 2019 | 09:11 PM
rk-d's Avatar
rk-d
Andreas
Strange - I have a LWFW. No bucket of bolts sounds. A slight rattle at low RPMs if I’m unintentionally lugging it, but otherwise there’s nothing really objectionable.
I saw a significant improvement - the car feels more aggressive and responsive. Heel toe is super easy - rev matching is a breeze. For me this was an all win, no downside modification.
Old Sep 17, 2019 | 08:37 AM
mhm993's Avatar
mhm993
Great on my track car. Would never consider for a street car.
Old Sep 17, 2019 | 09:02 AM
993pbug's Avatar
993pbug
Same situation for me - only slight rattle between 2,300 and 2,800rpm when lugging it with no other loose bolt sounds at any time. Otherwise, I am absolutely happy I made the swap as the engine revs freely when blipping on downshifts and throttle response across the range has greatly improved.
Old Sep 17, 2019 | 09:16 AM
pp000830's Avatar
pp000830
I wouldn't do it.
At one time I looked into the non-dual mass lightweight flywheel option and found that if you replace the flywheel with a lightweight single-mass flywheel be aware that you should expect a good bit of additional noise, per Luk testing data and Rennlist postings. Some who have done this like the concept and throttle feel of the simpler flywheel and feel it is a good tradeoff for a perception of improved performance. Others have found the noise bothersome. Luk testing has shown installing a single mass flywheel can accelerate wear on engine/driveline components due to increased torsional impact loads to the engine and transmission. Some have experienced idle problems with the lightweight flywheel requiring DME software changes to fully address.
Andy
Old Sep 17, 2019 | 10:45 AM
rk-d's Avatar
rk-d
^^^To be fair, driving the car will cause accelerated wear. I'm not aware of any reported failures linked to using a LWFW, but I suppose anything is possible. Ironically, I drive much smoother with the LWFW because rev matching is much easier, so there is some theoretical benefit there.
I doubt the LWFW has any quantifiable performance advantages. It's all feel. But that's enough for me. I'm not worried about numbers with this car.
That said - I would keep the eyes wide open about using this in a '95. I've read posts where people were not able to shake the stall issue even with a chip. I'd see what the chip guys have to say about it. I have a '98 and zero stall issues.
And if the trivial amount of noise bothers you, I'd suggest getting a Fister III and that will cover it up nicely.
Old Sep 17, 2019 | 11:35 AM
Mark in Baltimore's Avatar
Mark in Baltimore
My now-sold, 1995 race car had a PMNA lightweight flywheel and there was no bucket of bolts sound with solid motor mounts. However, when I installed the solid trans mount, that's when the bucket of bolts sound started; it was definitely noisy but not an issue for a track car where you're wearing a helmet and ear plugs and looking to shave tenths of seconds. For a street car, there is no way I'd put up with that annoying cacophony. Shifting was, of course, incredibly crisper.
I had some stalling issues on the street, but cleaning the ISV valve cured the problem for about 6,000 miles.
Tons and tons of threads on this topic. Keep in mind that people use LWFW, LWF, lightweight flywheel and light weight fly wheel and other variations when they start a thread or post, so knowing how to search is critical for this topic:
-Poll on '95 owners' experiences with the LWFW: https://rennlist.com/forums/993-foru...995-993-a.html
-New ISV valve cured stalling issues (great read with many other links in here): https://rennlist.com/forums/993-foru...m-new-isv.html
-Solid motor mount and noise thread: https://rennlist.com/forums/993-foru...on-mounts.html
Old Sep 17, 2019 | 12:29 PM
samurai_k's Avatar
samurai_k
If anyone is interested I have a new lwfw, ring gear, and guide tube for sale as leftovers. Will post details on the FS thread.
Price: $630 shipped
