Crank Case & Oil Tank ventilation
Two questions:
- Is there a vent hose that goes from the oil tank and or crankcase for the purpose of crankcase ventilation.
- Can one, and would it be advantageous to, add an oil vapor separator to such a hose to diminish oil vapor ingestion in the intake and ultimately oil byproduct buildup on the exhaust valves and the air injector ports?
Somewhat related. You may want to consider installing bleeder valves for your clutch in an accessible location to provide for easier bleeding....
