Caliper Painting/Refurb Vendor
Does anybody have a recommendation for a quality vendor for stripping, painting, stickering, then clear coating a set of 993 calipers? Wheel Dynamics (wheeldynamics.com) had a presence here for awhile but I cannot get in touch with them.
Thanks!
Thanks!
I'm currently having a 993 set done by Chris NYE @ SR Powdercoating. He's done many 993 calipers- good guy, excellent pricing, and he spends lots of time on the strip and prep work.. He's in New Hampshire.
603-493-5411. srpowdercoating@gmail.com
Noodle Jr.
I would stay away from WheelDynamics. I had a horrible experience of poor quality, poor communication and poor customer service with them. My caliper finish is still not perfect. It was a 5 month ordeal. Search the internet and you will find similar reviews.
I DIY my own caliper rebuild & refinish, but tried to go to WD for tire dismount, mount & balance. A huge waste of time and energy.
Wheel Enhancement gets my business, (not that they do caliper refinishing), while WD sucks!
I'm having SR Powdercoating do the finishing, and then I will do the rebuild of the pistons and seals... While he was at it, I also had him Ceracote the exhaust tips in black... Here's a shot of the calipers after they were stripped down and cleaned up, prior to powder coating..
These calipers are anodized. I would personally stay away from any method that removes this protective coating unless they are re-anodized prior to painting. PMB is the only place that I contacted that knew this - the reason I am going with them.
I'm surprised to hear you guys powder coating calipers-- I always understood this to be a major no-no, since if the car is ever tracked the coating will get ruined. Or so I've heard.
Basic Sponsor
I've seen some calipers change a slight color under extreme track use - I've had many calipers powder coated with excellent results. There is some thought that powder coating may retain the heat within the caliper but I have yet to see actual scientific testing confirming this theory. However I have always liked the anodized caliper with colored Brembo.
High Temp Caliper Rebuild Kits For Brembo Calipers; Caliper Pistons
Ohio Clothing
www.ohioperformancesolutions.com
2007 C4S F77 Aerokit / 2004 E46 M3 / 2018 M3 comp
Ohio Clothing
I had Ruben paint my calipers, when he replaced my evaporator, Clutch and installed a LWF. He now has a full up shop: http://everyonesgarage.com/about.html
so I would think you could send him your calipers.
My calipers didn't need any refurb, but Ruben is certainly qualified to also do that. I just had him paint and clear coat them. Been almost 6 years since I had them done, and they look perfect (though I've put less than 10,00 miles on the car since then)
