993 poor high rpm performance
*in the end a fuel pump and fuel regulator fixed the issue*
Hello ,
Question for the expert mechanic on here.
My 993 was ripping it pulled like a freight train to redline. Then all of a sudden in first or second gear at high rpm it backfired though the intake and died. Started right back up but now runs like in limp mode. Smooth idle and good midrange power but nothing on top and it has me puzzled.
Car does not want to rev past 5500rpm . Car is stock obd1 non verioram.
I figured in was was getting close to the 60k mark so I went ahead and did the 60k Service it needed it anyway.
This is what I have replaced so far.
-spark plugs Bosch
-fuel filter Mahle
-air filter Mahle
-distributor caps Bosch
-distributor rotors Bosch
-02 sensor Bosch
-cleaned isv
-replaced maf
- new ignition module
-air temp sensor on intake
- throttle position sensor
- new plug wires beru
even tried some fuel system cleaner.
Here is what I have checked.
-I pulled the coil wire to the distributor caps car runs on either distributor alone but, rough on secondary distributor.( is this a proper test of coil and ignition module * could I have a problem but only at say 5k rpm?)
- checked secondary rotor could not spin so distributor belt is not broke?
-checked the three vacuum actuators no leaks.
trace my vacuum lines all look in order. Car holds vacuum hours after shutoff.
-tested my intake flap it’s working on key on and startup.(but no idea at wot)
-no check engine light.
-checked plug wires look ok not terrible not perfect
*so so after the tune up the car idles and runs sooo smoothly clean up thu midrange actually I gained a lot more midrange power but lost the top end somehow just feels flat lost it’s punch if you know what I mean.
I noticed the fuel filter was quite dirty
maf was filthy * if my maf was bad would it throw a check engine light? (Went ahead and replaced it .)
could my fuel filter be clogged again? (Replaced it again)
weak fuel pump at 55k???
check my cat converter with inspection mini camera and catalyst looks* ok no build up .
thanks for reading any suggestions would be appreciated.
thanks!
Hello ,
-spark plugs Bosch
-fuel filter Mahle
-air filter Mahle
-02 sensor Bosch
-cleaned isv
-replaced maf
thanks!
Consider running the OBD Codes and see what comes back.
First thing I’d do, before spending hours and hours and several hundreds of dollars, would be to spend $200 on a dyno pull to see if there’s really an issue. Could be all in your head.
Looking at running data may reveal something as well. The fuel filter is rather high capacity so I doubt it is the issue. The butterfly in the throttle body or any related sensor on it could be out of adjustment where it is not fully mechanically opening. this seems reasonable if the car runs well in all other aspects. I would think a clog or restriction in the fuel system would result in a lean condition at near wide open throttle and would cause some sort of diagnostic code related to lean misfires.
I am not fully versed on the non-Varioram cars. There is an excellent paperback book published by Bosch on theory and diagnosing all versions of their fuel injection. It's inexpensive new or used on Amazon or eBay.
Hope I helped here,
Andy
I was thinking to use the diagnostic port with the correct round to square adapter if needed and an OBD Code reader.
Hope I helped here,
Andy
Hope I helped here,
Andy
Is there any adorable code reader/ diagnostic tool you would recommend?
so you’re saying a code reader may show miss fires but not throw a check engine light.
I have read about the butterfly valve % and gas pedal cable not fully opening I’ll look into it good idea!
When I changed my filter there was some very small rubber chunks when I dumped it out into a bucket. I attached a picture of it what do you think?
*Also my plug wires are original yes some of the lower ones have small cracks and a dry rotted look to them probably from muffler heat , could this be the issue and only arise at high rpm?
So you’re saying a code reader may show miss fires but not throw a check engine light.
Andy
To keep your cost down a reader that only reads emissions related codes is a good start I use an Autel 519 on my '96 for your earlier car you will need an adapter something like this:
19 pin OBDC Porsche Adapter, you will need to get a Porsche compatible one with the number of pins as on your car's socket. I am making a small leap of faith that an adapter will work with the Altel 519.
A more functional reader is a MSWindows Laptop used with a Durametric cable and software. Their lower cost solution is still rather expensive but it will read all the modules in a 993. On your earlier car, I am unsure if modules other than engine emissions can be read, on my '96 Engine, ABS, HVAC, Airbag, Tiptronic (if present) can be read and codes cleared. Durametric offers a cable adapter for pre-1996 OBD Porsche vehicles
Misfires are counted by the ECU on my '96 if above a certain %/count the light goes on and a code is thrown, it seems to reset and the light goes out if the root cause of the misfire is fixed, not sure on the earlier cars.
I have read about the butterfly valve % and gas pedal cable not fully opening I’ll look into it good idea!I have read about others having this issue.
When I changed my filter there was some very small rubber chunks when I dumped it out into a bucket. I attached a picture of it what do you think?There is always some debris in a gas tank. The fuel pickup and the filter are designed to deal with this. The only time I have had experience with debris clogging the intake was with a lawnmower where it would stall out shortly after starting when the debris would collect around the fuel pick-up. I have never heard about this with a car. much less one with a plastic gas tank where rust cannot be an issue.
Also my plug wires are original yes some of the lower ones have small cracks and a dry rotted look to them probably from muffler heat , could this be the issue and only arise at high rpm?This should be addressed before exploring or spending money on anything beyond checking the butterfly position as bad wires can induce all sorts of performance issues. If your wires are cracked they are way beyond needing replacement.
Good luck with this,Andy
If everything else checks out ok, you might have a clogged catalytic converter. Perhaps you could borrow a bypass pipe from someone to see if it makes a big difference.
RL Technical Advisor
Check long term fuel trims to see if its lean or not.
Replace those plug wires!!! (LONG overdue)
Don't forget about the in-tank fuel filter if you've seen any evidence of fuel contamination. I always cut open the old (main) fuel filter for inspection.
I don’t think because this happened all of a sudden one day after some hard hi way on ramp pulls to red line
Andy
