Help! Lost fob, no spare.
Long time 993 owner here, 20 or so years, now on my 3rd one and have logged close to 100K miles both daily driving and now as a weekend driver. Yes I've read lots of threads on the immobilizer etc.
My current '96 993 is the first one I've bought with only one set of keys. Knew I better have a spare but the dealer wanted $650. So I bought blanks and the fob from Suncoast for somewhat less. Took the car and the key/fob to San Diego Porsche on Miramar Road to get the spare fob programmed (quoted $200 for that if I remember correctly). Wasted $80 on Uber and several hours of my day, only to be told when I returned that they couldn't figure out how to program the fob. So I sort of gave up and forgot about it.
Fast forward to today. Somehow managed to lose my one working key/fob. Don't ask. Car is in my garage, and I do have a key cut that will open the door and turn in the ignition. Is there any way to start the car without the remote/fob? Not sure what to do at this point. If the dealer here couldn't even program a second fob with the car and a working remote in hand, I'm wondering WTF my options are now. Any help or advice would be greatly appreciated!
Different dealer??
Hard to believe its any more complicated than reading the key and adding it to the key list in the ECU,,,
This has been pretty standard on the german rides since OBDII came out.
Last I checked you have to have the car at the dealer to get the key bonded to the car.
Got a new one for my car last week, was very drama free.
03 C4 Cab...
03 C4 Cab...
Different dealer??
03 C4 Cab...
03 C4 Cab...
https://www.ebay.com/itm/Porsche-Car...8AAOSwGvhT0ZnP
https://www.ecudoctors.com/porsche-9...361825902.html
Yes with electronic fobs it is easy to get stranded. It is even worse with some modern car's fobs that can't be programmed by the dealer and have to be sent away for as one's car sits.
To mitigate this, we take two complete sets of keys with us when we go on road trips in our other car.
I have two sets of 993 keys and keep an extra fob and fresh battery in the frunk in case of a fob failure while not home.
Also, many new and used ones on eBay, If you buy a used one verify the FCC number is correct for a 993. It is usually printed on the outside of the housing. I believe all switchblade style Porsche remotes are for a 993 however the key and separate fob style housing was also used with the 924S, the 944, the 1995 993 and some folks have switched out their switchblade key gut into the 944 housing so not all of them work with a 993 even though they look identical.
Andy
USA Catalog:
Andy
USA Catalog:
Your Ebay link seems to be for a 95 fob vs the 96 or 97-98. Will that work on the later cars? The Ebay page seems to indicate it will work with all years but the document image separates into the different years.
Andy
USA Catalog:
Andy
USA Catalog:
There are other fob offerings on eBay, in fact, one seller is selling a pair of fobs in one auction. eBay=buyer beware.
Andy
Andy
USA Catalog:
Andy
USA Catalog:
I'll see you July 4th.
Programming a 993 immobilizer is very simple:
1. Open door, insert key, and turn key to run mode. Immobilizer light should come on.
2. After about 15 seconds, the light should go out. Turn key off then on (cycle key).
3. After about 15 seconds, the light will start to flash. Cycle the key to enter each of the four digits. Wait about a second between each digit.
4. If the code is correct, the light will begin to flash. Depress the button on each of remotes.
5. Turn the key off, exit the vehicle, close the door, and test each remote.
If step #3 doesn't occur, the ignition switch is bad. The immobilizer then needs to be programmed externally. Many who repair Porsche ECUs can do this.
I just took my car with immobilizer issues to the local shop, I have a bad immobilizer "brain".
He is replacing the whole unit with a third party fob for about $200. He says a refurb immobilizer will run about $1000. I have 100k miles so factory wasn't that important.
Maybe that could be an option for you as well.
Thanks for all the useful info. After several more hours of searching, I found the working key/fob stuck down in the back seat seatbelt well of another one of my cars. I'm surprised I found it, could have been there for a long time and I'd never have seen it the way it was lodged. Now I have to get the spare one programmed pronto!
Also, if I do this on my spare key and get it wrong, won't it also reset the system so that my currently operational key is no longer useable? If so that's a risk I'd rather not take. I need to find a dealer who knows how to do the job I guess. Not sure why Miramar Porsche couldn't figure it out. They are a major dealership that also has an official "classics" division selling older/vintage Porsches.
Both keys (original/new) must be coded at the same time when the light begins flashing, or the original won't function and the procedure must be repeated.
