Warning lights issue c4 1997
This is all I can find:
On the latest Porsche models, it means "Turn the steering wheel so that the steering wheel lock can engage/disengage."
Yellow Flashing: Malfunction in the electronic steering column lock.
Red Solid: Power steering assist failure.
Red Flashing: Malfunction in the electronic steering column lock.
Steering general for German cars:
Yellow Solid: Power steering assist reduced.Yellow Flashing: Malfunction in the electronic steering column lock.
Power Steering Warning Light, Fluid and Failure
This light, a steering wheel and exclamation point, indicates that your vehicle’s power steering fluid levels are low or that there is a fault in the system. The steering wheel looks slightly different depending on the model of car or truck.
Technical Guru
Spot #4 on the clock is for the immobilizer and that is an aftermarket gauge face from FVD with a custom icon.
More than likely your immobilizer has failed.
Originally Posted by RWB Nordics
The red light flashing constantly also while driving
This light, a steering wheel and exclamation point, indicates that your vehicle’s power steering fluid levels are low or that there is a fault in the system. The steering wheel looks slightly different depending on the model of car or truck.Trending Topics
