Help starter issue
Help starter issue
Went to get the car washed ...after it would not start not even a click. All electrical and battery perfect except starting.
In 24 yers it has has always started on the first twist.
relay..which one ..fuse..or did something get wet..ie power wash.
please help as I am parked and can’t get out when needed!
Thanks everyone ahead of this. Cheers
Started but
She sat for awhile and turned the alarm on and off. Blamm she started but....
What caused it ? As I said not once in her entire life has she not started. Winter summer no worries.
built date 2/94 so no alarm issues.
So where could water have touched after a major power wash?
That this could happen?
Or more...
As starters go bad, they can stick, hitting with a hammer DOES work. I had this problem on my 911SC and while I waited for my rebuilt starter, I would push start the car (actuall park on a slight slope, let it roll, then pop the clutch. I lived with my SC like that for about 2 months...daily driving it.
whether or not it will work in this situation remains to be seen, the hammer trick only works if the spindle is getting stuck.
As stated, it won't fix the starter, but it can get you going again so you aren't stuck.
I prefer that probelm, as when the starter went on the 993, it shorted out and push starting wasn't and option, not to mention it killed the battery.
I haven't heard much about this issue on our cars, but I've had to replace a few ignition switches on other makes for exactly the same symptom. 24 years of arcing can make the starter switch contacts become intermittent. Just a thought.
While you don't have the immobilizer, our 95's still have drive block
my guess is some strange time out conditions temporarily thwarted your attempts to start
monitor over the next few trips and see if things return to normal
locking the car and then unlocking should reset any theft protection devices
What is the difference between Drive Block and Immobilizer? I thought Porsche's branded immobilizer was called Drive Block?
Also, the original poster should not look too deeply for the problem. If the battery is at 12.5 volts or more at shut off and the system runs at 13.5 ~14.2 Volts when running I would clean the battery connections and be done with it. I would not attribute the problem to the starter. It could have just been some unrelated electrical noise in the system causing a no-start condition that is apparently cleared at this point.
Andy
Andy
OP the key datum you offered is the car wash. What part of the car gets wet in a car wash that could affect starting? The coils, distributor, and ignition wires. Check there first.
The starter is on top of the transmission. You'd have to drive through a tornado to get it wet.
Turned door locks on and off with key. Problem solved but hmm that was weird!
Never going back to over washed detailer with power washer.
She starts like always on the the first twist!
Feeling good!
Feeling good!
