Help....Metal on oil drain plug
meandean,
Don't panic yet. We can certainly rule out the crankcase/block(nonmetalic).
The coil is too tight to be any bearings too. My guess is pulled threads. What service work have you had done lately? Sparkplugs?
Metal fragments from pulled spark plugs would not end up in the oil would it?
Do the bits look like shavings or do they look broken off a larger piece, also do any of the pieces fit together to make a more recognisable part?
Alan
Alan
