KW V3 owners chime in...
Simple question - what's your ride height?
I'm getting these installed along with a bunch of other things. I want to try to and get this thing on point. I've read all the threads I can - not a ton on the KWs. Seems to be some disagreement on the optimal ride height settings for these coilovers. RS vs RS+10. Right now, I'm leaning towards the latter, though I love the look of RS ride height.
Any other helpful tips appreciated.
Do you have stock front uprights? If so going lower than RS +10 will produce bump steer. Bump steer kit will help but you will really want RS or BBI uprights to go RS low.
I used to have a GT4 which was pretty low to the ground. Not sure if RS ride height is much different than that from a practical standpoint, in terms of scraping. The GT4 had a long lip and this made the approach angle tough. As of now, I have the standard C4S (ie Turbo) front bumper.
With the expense of everything I'm doing now, RS uprights (which I thought were discontinued) and BBI uprights are a slippery slope that I want to avoid.
Yeah, I am not planning on buying the bump steer kit if going RS+10 - I had resigned myself to getting the kit if I went RS height, however.
I have KW's and RS uprights and bump steer, and a bunch of other Tarret bits also. My height is pretty low. I got uprights from sunset porsche, they have them instock.
Here is my suspension set up thread: https://rennlist.com/forums/993-foru...up-choice.html
I have RS +10 with KW V3s
The height definitely does not seem too low. Plenty of clearance, and if you want to do RS, it seems like the height would be fine.
I have heard that bump steer can be bad, but I don't notice much. The car is a little "darty" but it may be a function of the new alignment (RS). If you like the look of RS, I would do it. You can either buy new uprights, or live with the bump steer. I suspect that for a street car, the horrors of bump steer are probably overblown.
The V3's have a specific adjustment range, I measured the front with calipers yesterday, and it seems like it covers from RS+15 down to below RS. It will go much farther in each direction, but those are the limits that KW recommends.
Thanks for comments so far - some cool looking cars...
Looks like between uprights, tie rods, bearing and added labor — probably ~$2k additional cost, if not more. May have to stick with RS+10mm for now. I think I can get away without the bump steer mod at this ride height...
Doing LWFW/RS clutch, Fister exhaust, KW v3 coilovers and engine out stuff as it is... the slippery slope comes quick.
Seb - thank you. I don’t want to ride that low, so really more interested in how high they can go. Target would be RoW sport, which is 144/127 (F/R). Do you know? Thanks again.
I wanted my car low hehe
