993RS pulley setup
993RS pulley setup
Just to wrap up a thread from Dec. here are the pieces necessary for a 993RS single pulley setup.
- 993-106-051-80 impeller hub for the alternator
- 993-102-050-40 pulley for the crankshaft
Originally Posted by 993James993
Bill and the rest of the gurus here, I need to replace my alternator and thought I would upgrade to the RS Pulley. I ordered and today just received the 993-106-051-80 impeller hub for the alternator, along with three nuts.
I did not order, nor do i have, the 993-102-050-40 pulley for the crankshaft.
Do I need this part. It seems obvious that I would.
Did I misunderstand the DIY's regarding this? Are there any factory instructions that I can give my mechanic?
Thanks everyone for your help!
Jim
Jim
One caution... if you go to the full RS setup, the battery is only 35 ah and the electrical output from the alternator is on the limit if you run all electrics simultaneously... stay out of traffic snarls!
