993 Control Arm Toe Link
Just recently installed KW V3s on my 95 NB. My tech said he noticed that the rubber housing/boot on both rear control arm toe links are almost completely gone -- advises to get it replaced.
1. How serious is this? should this be replaced ASAP?
2. Thinking of replacing them with these https://www.pelicanparts.com/More_In...iABEgJfPvD_BwE
Are these good enough for street and occasional canyon runs? Seems like good value for the pair.
Whats the difference compared to the Tarett ERP ones that are priced at $310 each (https://www.horsepowerfreaks.com/-p-...CABEgKiu_D_BwE)
stock toe links have rubber in the joints this allows for a more comfortable ride w/ less abrupt motion. The Tarett and Rennline replacements have monoball links that tighten up the ride a lot, motion will be much more abrupt and limited.
You can use either on the street but monoball links are more track oriented, and also more subject to wear. If you use them do get the protective booties and occasionally spritz in some lube (WD40 works fine) you will also want the eccentric locks for the inner ends
If you are doing lots of track work, the extra precision of the mono-***** may be worth it.
