993 Forum 1995-1998
Wheel Spacer Question
Old Jan 21, 2003 | 09:55 PM
Ron's Avatar
Ron
Question Wheel Spacer Question
Has anyone installed 25mm spacers on a widebody and if so did you need to install longer studs? I'll be using aluminum lug nuts.
Old Jan 22, 2003 | 12:56 AM
Matt Vaughan's Avatar
Matt Vaughan
Post
I have factory spacers on my car, due to the fact it came with 17" wheels. The factory spacers bolt onto the existing bolts on the wheel hub -- more convenient than fitting spacers with longer bolts, particularly when switching out different wheel sizes.
Old Jan 22, 2003 | 02:29 AM
SoCal-CJ (993S)'s Avatar
SoCal-CJ (993S)
Post
will there be spacers on a C2S with 18's?
what mods are neccessary to put 8.5's and 11's on a car that has 8's and 10's?
Old Jan 22, 2003 | 02:31 PM
Matt Vaughan
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Arial,Helvetica,Geneva">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Originally posted by SoCal-CJ:
<strong>will there be spacers on a C2S with 18's?
what mods are neccessary to put 8.5's and 11's on a car that has 8's and 10's?</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Mine does since I have the narrow body offset on the rear wheels (65ET). Cars that came from the factory with 18's did not have spacers.
You should be able to fit those wheel sizes on the car without modifications, provided you get the correct offsets.
