MY02 Carrera Wheels Photos on 993 Plus weight and handling differences.
Originally posted by JMc
Mike - your car looks great with the new wheels. If I may ask, what caused you to start running a front license plate?
1 Post
Boxster MY02 rims
Originally Posted by Carrera Mike
[COLOR=red]
Just note that there are 7X18 and 9X18 which are for the Boxster. The 8X18s and 10X18s are the ones that will have the proper fit for the 993.
Pardon my ignorance - but will the Boxster MY02s fit on a NB993 properly? Just need to add spacers?
Alan
Alan
Alan
1 Post
Originally Posted by kkim
nope.
My question is - the guy selling these rims is actually running these on his NB 993 currently- so in what sense are they unsuitable for a 993?
Is it a safety issue? If not, what is the concern?
Pardon my ignorance once again, and appreciate any input.
Thanks.
Alan
1 Post
More specifically, I have now been told the width of the rims are 7" front and 8" rear with 50mm and 52mm offsets respectively.
Correction: the width of the rims are 7" front and 9" rear with 50mm and 52mm offsets respectively.
More specifically, I have now been told the width of the rims are 7" front and 8" rear with 50mm and 52mm offsets respectively. I presume these are the Boxster MY02s which a number of you have advised are not suitable for a 993.
Thanks.
Alan
Thanks.
Alan
The only reason IMHO is either because you can get an outstanding deal (they can be made to look OK and fit the wheel wells with spacers but you should add the cost into you calculation) or because you want to run snow chains so need the additional fender clearance (especially in the rear).
The Boxster MY02s will limit the size tires that you can run...with 7"/9" the proper tire size is probably 205 in front and either 255 or 265 in the rear. (FYI my car below now runs 245 in the front on a 9" ET40). Using 8"/10" MY02s lets you run up to 235 and 295 and using spacers is optional since these offsets are pretty close to ideal as far as filling out the wheel wells IMHO.
1 Post
Thanks for the advice David.
Havent made up my mind on these rims - it's just that there's a 2nd hand set is being offered to me - wish they were the 996's but they are not. And am checking with you guys as to the whether they are suitable or not.
What is the going price for these in HK? What do you think would be an outstanding deal?
Alan
Alan
