Supercharger Boost control
For those of with a TPC SC...
How do you control boost in the system? I will be adding a custom intercooler, and wanted to know if the supplied boost valve is adjustable?
Just remember that the pulley controls the boost, but the altitude and barometric pressure will determine how much pressure you actually get. If you drive up a mountain, you'll have very little boost. I've driven supercharged cars at high altitude that felt like the parasitic losses of the belt-drive friction were grater than the extra power from the supercharger. And if you adjust the pulley to give proper boost at high altitude, you'll risk detonation at sea level. I realize that this is not an issue for those of you near the coast, but I drive anywhere from 4,000 ft to 12,000 ft above sea level which makes superchargers very impractical (this is turbocharger country up here in Denver - or high-compression N/A). Just thought I'd mention this to people similarly situated...
