New sound: pending clutch problem?
I've noticed a new sound that has me wondering about my clutch. When easing the clutch out from a full stop, i hear a noise that reminds me of the sound of a failed bearing in the spoiler drive transmission, when the spoiler is retracted. The noise goes away once the clutch engages, I only hear it during the transition. Any ideas?
The clutch was replaced less than 12k miles ago, along with all the while you're in there stuff (DMF, RMS, fork, and slave cylinder).
Throw out bearing.
Was the pilot bearing replaced and lubed with the clutch replacement?
There are a few different friction plates specified for a 993 some have coil springs that could conceivably rattle when spinning and not under torque.
Other's thoughts on if this? Is it possible?
The noise in question is a recent development. The noise is not present when idling in neutral, regardless of whether or not the clutch is engaged. The noise is only present during the 1 or 2 seconds during which the clutch is gradually being engaged when taking-off from a dead stop. Other than that brief transition period, there are no strange noises and the car shifts through all of the gears like the day it came out of the factory. Is this behavior consistent with a bad throw-out bearing? I'm starting to think (ok, hope) that I might be hearing a vibrating heat shield. I plan to visit Haydon Bros this week and see if they can isolate the source.
On my rs i went through 3 pressure plates and 2 throwout besrings. All bad after a few 100 miles all Porsche parts. It happens. It sucked. It wasn’t the shop the Porsche parts were bad.
That said tob you hear on clutch engagement.
Can you post post audio or video?
Not sure about this, but isn’t the pilot bearing a sealed roller bearing? I think the last one I replaced years ago was a sealed unit and not a brass bushing. If Porsche puts sealed bearings in the front hubs why would they put a serviceable unit in an inanaccessibe location. Not at home to check the service manuals or Porsche PET. When I get home tomorrow I’ll check and report back. As usual, just my opinion, I could be wrong.
JC
98 C2S widebody
JC
98 C2S widebody
Does the sound only appear when it's cold outside and car is cold? My car made these sounds in these conditions due to belt tightening from cold and fan/alternator bearings were going.
Thanks for all the suggestions. I got under the car today with a rubber mallet, to see if I could find some sheet metal that might be loose. I think that I found the problem. When I tapped the shield between the catalytic converter and the bumper with the mallet, the sound seemed consistent with the noise that I've been hearing. I found that 3 of the fasteners that mount the heat shield between the bumper cover and the catalytic converter were loose. Sorry for the lousy photo.... these fasteners are located along the inside edge at the bottom of the bumper cover. I tightened all of the fasteners and went for a test ride, the noise seems to be gone. Does anyone know if these are the standard fasteners for the heatshield? It seems very un-Porsche-like. There are very large holes (or slots) cut into the heatshield, and these fender washers are used to clamp the shield to the inside of the bumper. The fender washers are not quite wide enough cover the large cutout in the shield. I looked at the PET; but, I can't tell from the drawing if these are the standard fasteners.
