Momo horn - is it wired correctly?
Hey guys,
I installed my Momo steering wheel today and the only issue I’m having is that the horn isn’t working. I wired everything according to the DIY RS install and I don’t have any airbag light. I’m just not sure how the horn button needs to be wired. If the picture below is correct, I’m thinking maybe my horn contact button isn’t bent out enough. Appreciate any and all help.
Technically the central terminal on the button is power so your leads are reversed but it's a simple switch and shouldn't make a difference. If you touch the two wires together the horn should sound. Most likely the L-shaped horn contact lever you installed on the multifunction switch (aka turn signal switch) is not making contact with the horn ring on the momo hub. You will need to slightly bend the contact lever out or grind away a small section of it for it to touch the horn ring on the hub correctly.
Got it sorted out - everything works as it should. And wow, what a dramatic difference in driving experience by adding the aftermarket wheel. I can feel all the little bumps in the road and the steering just feels much more precise.
i know what you mean. i put a new steering wheel on mine about a month ago and i honestly can't believe the difference. cheers.
