Massive Engine Fan Failure - Any Ideas as to the Cause?
Pretty much self-explanatory. Any ideas welcomed. Fan is new btw - installed about one year ago because the old one had cracks.
Seared
As Steve already said. But for a 'new' fan, I'd suspect worn alternator bearings, worn fan hub bearing, a distorted fan housing from overtightening the strap, or something was sucked in while the engine was running. If one blade shears off, others will likely follow as the fan does its best imitation of a Cuisinart food processor...
Andreas
Andreas
In any event, you need to replace it as having metal shards potentially flinging around in the engine is generally not a good idea. When you remove it carefully inspect the top of the engine cylinders behind the alternator as some of the shards may be in there. I would recommend using a belt tensioning gauge when reinstalling the belts to avoid inducing clearance issues as a result of over tightening the belts. Once the new belts are in place run the engine for a short time to seat a little and check the tension again.
Andy
Andy
Received 5,414 Likes
Andreas
Andreas
RL Technical Advisor
The TT fan is hard-anodized aluminum with some performance improvements and the last fan one will buy.
FYI,....its not interchangeable with the N/A version; one also needs the TT shroud to make it work.
Seared
We do make 993TT fans since Porsche has discontinued that part but as Chuck said, I won't tackle the 3.6 N/A fans unless the Factory quits making them.
Can you post a pic of your TT fan?
Andreas
All, many thanks for your thoughts and suggestions - sorry I haven't posted earlier, but... work
The shop has inspected the fan and shroud, but weren't able to find any obvious culprit. I will naturally not run the car with this fan - I'll but a new one, and in the meantime I'll run the replaced fan, who has a small crack, but is otherwise ok. I kind of regret now having replaced it with the one that broke ))
Anyway, one question - do I need to replace the shroud as well? The blades in the shroud have been 'pinched' a bit where the broken blades/material from the fan have hit it while being still spun by the fan.
The reason I'm asking is because a new shroud costs an arm and a leg - normally it should still work, but I wonder how the small pinches affect the airflow on top of the engine.
