Air Fuel Ratio Question
I have seen several dyno sheets in the past, but am unable to find any of them using the search function. I am trying to find out what is a normal air fuel ratio for a normally aspirated Varioram 993. My car is under 14.0 to 1 until 5500 rpm where it goes to 14.2 to 1. Is this similar to your results?
Thanks in advance,
Hank
Thanks in advance,
Hank
First the disclaimer--I am no expert on this. But, that sounds too lean at high RPMs. On my car, it was around 12.7 to 1 at high RPM. I was told mineAround 14.7 to 1 at idle is about right, but for max power and cooler engine temps it should be around 12.5 or 13 to 1 at high RPMs. Steve W, of course, is the man on this topic, as well as many others.
RL Technical Advisor
Hi Hank:
Lots of variables here and throttle position is the biggie when talking about A/F ratios.
Depending on load, it will vary from 16:1 to 13.5:1 in stock chips.
I like to see 13.2:1 at full load, WOT.
Don and Steve:
Thanks for the help. I actually found several of the posted dyno sheets by searching for "dyno results."
You guys are right, of course, about making safe maximum power around 13.2. I was just curious what the air/fuel ratio graph of a stock engine with a stock chip looked like.
Steve, as you are aware, I am still fighting my over-lean problem. I think we are close to a solution. I'll keep you posted.
Hank
Hank
Hank,
I've got some Dynojet files of my car if you want them. Email me and I'll send them to you. You can use the Dynojet RunViewer to look at what ever you want.
George
George
George:
Thank you. I may take you up on that later today. My car is at the dyno now and I should have all the information about my car for comparison later this afternoon.
Thanks again,
Hank
Thanks again,
Hank
FYI, I believe 14.7:1 is the ideal stoichiometric Air/Fuel ratio for gasoline combustion. Usually a bit richer (numerically lower first number) to get optimal power, at the [slight] expense in economy.
-Chris
-Chris
George:
Thanks again for your kind offer. My problem is solved. It turned out to be an injector issue. Now, A/F ratio is much more normal as are the HP and Torque curves.
Thanks again,
Hank
Thanks again,
Hank
