993 Forum 1995-1998
What do do with unused bulb connectors
Old Sep 23, 2018 | 01:50 PM
GBX's Avatar
GBX
Default What do do with unused bulb connectors
getting ready to install some Turbo S ducts as well as Amber rear corner lights. What should I do with the unused connectors, fog light plug in the front and that 3rd bulb plug in the rear? Should the bulb socket come off the wire first? Is there a proper way to “tie” these up to prevent water from gettting in there, etc? Thinking maybe just some electrical tape?
Old Sep 25, 2018 | 07:11 AM
GBX's Avatar
GBX
Anyone? I’m sure it’s simple but looking for the proper way to handle. Thanks!
Old Sep 25, 2018 | 11:05 AM
Allen's Avatar
Allen
From the lay perspective, I would just put a bit of grease in the connector to prevent moisture from mucking it up over time...then wrap it in in electrical tape...then tie-wrap it out of the way.
Old Sep 25, 2018 | 01:05 PM
TheBen's Avatar
TheBen
That's what I did when I had the ducts. Zip tied away and I put a little balloon over the connectors. Everything worked perfectly when I went back to stock.
