Weird Tramont Cup Wheel dirt pattern
I know that on most 3 piece wheels there are torque specs. When I sent my Fikse wheels into Wheel Enhancement for a "refreshing", they split the wheel, added inners and outers as required (needed 1 of each) added new gaskets and torqued the wheels to Factory Specs. I am certain Tremont has torque specs.
BTW the Wheel Enhancement experience was epic, incredible service and very knowledgable.
No such issues w. OEM Speedline wheels and I've been fortunate to own a couple of sets of those. It appears that they are clear coated after being bolted together and there are no gaps where dust and grime can hide. It doesn't look like Tramont produces them the same way... The bolts are also different on the Tramont wheels so that may have something to do with it as well.
On a side note most alloy wheels makers have started that way to later gain enough influence to supply directly manufacturers
I hate listening to them.
I run two sets of Speedline Daytona's with polished lips (no lacquer) and do not have the issue mentioned by the OP.
Tramont use a different wheel fixing which obviously is not sealed against the rim lip which is causing trapped moisture to expel outwards when on the move. Not much you can do apart from split them and address the mating surfaces.
C.
C.
