Minimum safe distance from airbag on deployment?
I've been trying to get my wife to drive the 993 more often, and might even have her talked into an autocross...but I was watching her this am, and I noticed how close she is to the steering wheel.
She's only about 4' 11", so she puts the seat all the way forward, all the way up, and has a tiny pillow she sits on...works fine, and she doesn't slide around, but I'm wondering in the event of an airbag deployment...is there a minimum distance you should be from the airbag so it is helpful and not just an explosively propelled problem?
Thanks,
Thanks,
Good question; my teeny tiny wife also sits closer to the wheel than I'd like to see. Here's a couple of quotes I turned up on a web search:
"The recommended minimum distance between the driver and the steering wheel should be 18 inches. Anything closer could possibly result in severe burns and chest and arm injuries."
(from <a href="http://www.ucalgary.ca/UofC/faculties/MGMT/inrm/industry/product/airbags/webproject.html" target="_blank">http://www.ucalgary.ca/UofC/faculties/MGMT/inrm/industry/product/airbags/webproject.html</a>
And:
"To allow sufficient space for the airbag to deploy in an emergency, your chest should be a minimum of 20 cm from the centre portion of the wheel containing the airbag. Preferably, you should allow at least 25 cm (about a wrist to elbow worth) of space." from:
<a href="http://www.globeandmail.com/globemegawheels/20001109/driving.html" target="_blank">http://www.globeandmail.com/globemegawheels/20001109/driving.html</a>
These are both Canadian references, and I'm not sure if US and Canada have the same standards for airbags. I once read something that suggest that Canada had - or should have - "gentler" airbags because a much higher percentage of its population wears seat belts - the US airbags are supposedly designed to protect occupants who aren't wearing belts.
And:
Airbags were originally designed to protect a 170 pound, male who was not wearing a seat belt. Is there any benefit to paying $500 for a front airbag if you are wearing a seat belt? Are front airbags deadly to small people seated too close to them - YES!!! I wish airbags were optional!
I wear a seat belt and am a tall guy so a front airbag is so far away it is of no benefit to me. If I have my hand on the horn when the airbag deploys, it will probably break my hand as my hand impacts my face and breaks my nose - not to mention burns on my arm.
Side impacts to the head are the most deadly and side impact airbags could be very beneficial.
Regards,
George
In sunny Arizona
Regards,
George
In sunny Arizona
