993 Forum 1995-1998
Knock Sensor Bridge
Old Aug 19, 2018 | 02:46 PM
RBP's Avatar
RBP
Default Knock Sensor Bridge
I have a 1996 993 C2 and have just done some top end work. Was looking at putting things back together and when I looked really close I noticed 1 of the 6 bolts that fastens the knock sensor bridge down is longer than the other 5. Anyone seen this before or know why. Don't see anything in the shop manual, as they all appear to be the same.
Old Aug 19, 2018 | 03:28 PM
ras62's Avatar
ras62
If the same as the 964 they should be 30mm long and the length is critical to them working correctly.
Old Aug 19, 2018 | 06:42 PM
RBP's Avatar
RBP
The bolts are correct except for one bolt which is longer. Just trying to figure out why. I didn't notice when I took it apart and the photos I took doesn't show it. Maybe someone else worked in there and used the wrong size bolt. Before going there I thought I'd ask here first, its possible that the longer bolt also is a hold down for another part.
Old Aug 20, 2018 | 01:02 AM
BobbyT's Avatar
BobbyT
Hi RBP,
The Porsche PET parts catalog calls for six M6 X 30 bolts for the two knock sensor bridges, all bolts the same.
Old Aug 20, 2018 | 01:44 PM
Jlbarnett's Avatar
Jlbarnett
Sounds like someone lost one in the cars past. From what i remember they are all the same length, torque value is important
Old Aug 20, 2018 | 04:05 PM
RBP's Avatar
RBP
Ok, just checking. Am replacing the bolt with a M10 x 30 and moving on. Thanks for the input.
Old Aug 21, 2018 | 05:52 AM
ras62's Avatar
ras62
M10? Will not fit in a 6mm thread. Maybe confusion as the nut takes a 10mm socket. You need M6 X 30mm.
