H&R 993 Front & Rear Sway Bar Bushing Replacement 33954HA & 33954VA
I am creating this thread as there are many searchable threads on replacement bushings but none on the 33954 VA & 33954 HA versions.
I am really a huge fan of H&R but their customer service is a bit annoying. I wish they would sell directly to their customers, but whatever.
As a customer you are forced to reach out to their distributors to order these bushings.
For 33954 VA (front) sway bar the bushing reference number is 70953
For 33954 HA (rear) sway bar the bushing reference number is 71953
I hope this helps someone in the future.
Best,
Paul
H&R's phone number: (888) 827-8881
Best,
Paul
I had needed new bushings, and wanted urethane. Ordered the Prothane bushings as close to the 24/26 mm as possible. I then heated the correct diameter (just shy of it) socket, and melted the inners of the Prothane bushings. Worked well and still in there.
Front or rear? Front have specific droplinks for AWD vs 2wd. For rear, depends if you are mounting under or over rear links. Stock is over, RS is under. I think with these bars you mount over. I've got a rear one I never ended up using from a member here and it mounts over with the shorter links.
I run the RS bars with tarrett links.
Originally Posted by sacman
Do RS drop links only work on RS sway bars, at least the rear?
