Update oil pressure gauge
Now my oil pressure gauge reads 4 1/4 bars at anything above 2000 rpms and stays there until I slow below 2000 rpms, which then drops to 2 bars. Is this normal?
This is usually associated with oil pressure sending unit. Although, what you describe sounds semi-normal. You might want to post a video of the gauge with a few seconds of idle and a few seconds of revving.
Ginch...........Since my last post I pulled the gauge out and cleaned the terminals......
nile13..........at idle, the oil pressure gauge is steady at 2 bars......when revving it shots back up to 4 1/4 bars.....
In my experience the pressure gauge and the oil level gauge are not accurate on a 993. That's why we all check oil (should, anyway) via the dipstick.
Also, gauges seem to behave differently right after an oil change.
