SAI Code Source: Bad Check Value Job?
Good article here. I did the SAI last year- it was bad for sure. The valves however and the engine are super clean. I don't burn any oil and the ceramic on all of the valve guides are still white with no carbon build-up. I still throw a 0410 code now and then. I am pretty certain it's one of the o2 sensors- they are $ 100 bucks each and there are 4 on my car so I am going slow with this.
Plus most of the parts are marked up over double what they cost the shop (the gasket set is $300, not $617). Also surprising they say the case through-bolts are leaking. How much track time has this engine seen?
As far as this shop is concerned I would run for the hills. These guys view you as ignorant and wealthy. Bad combo.
SwayBar: What were the codes that told you this? Think I need a better Code Reader (using a iPhone based one), suggestions?
OP's engine has been burning oil its whole life, so no surprise SAI ports are clogged at 62K.
993 valve guides were not Porsche's finest hour. There should have been a recall, but the problem was so significant it probably would have bankrupted the company. So they moved the goalposts.
Alright looks like I found one source:
http://www.systemsc.com/codes.htm
Look for codes: 0130, 0140, 0150, 0160
There are other pages out there with this information.
I think it was throwing a 0150, bought the appropriate Bosch O2 sensor, installed it, and BANG, problem gone! I was really happy and surprised the codes worked so well.
If there were, the people who buy Porsche 911's new, certainly have the wherewithal to solicit a law firm capable of initiating a class action suit against such a company with deep pockets.
It seems more likely, that shops that make their living on selling top-end rebuild's are more than happy to propagate such a global claim.
I am not saying the Porsche valve guide material selection could not have been more robust,; nor am I implying that there were zero, out of spec valve/valve guides as shipped from the factory.
I am simply saying, that all things being equal, one scenario would seem too far outweigh the likelihood of the other.
Again, the shops performing repairs, are happy campers.
1) He was pretty quick to say that if I am getting the cods 0410 and 1411) it is likely clogged SAI ports and not something else (O2 sensor, vacuum leak, etc). He did not seem to think that a shop could mess up putting in the check valve
2) He said that flushing and routing out with wire really don't work, no way for fluid or wire to get all the way through the blocked passages.
3) He basically said do the rebuild
4) I share the outline of the quote I got and he said that sounded about right for Top End and a clutch, no recreation to the clutch at this low mileage.
Really appreciated his time and direct answers (much better than some I have to but disappointed he did not have a magic solution for me. I was curious about comments here that costs were high and after hearing from RMG I thought i would at least check part prices. The attached compares prices I was quoted against Pelican Parts (easier to search quickly, appreciate recomendation for other vendors to check). With a few expectations prices seem in line so not sure what to make of that. Appreciate the observation that the flywheel may be fine and agree I am not sure how they know that needs to be replaced. This made me curious about a couple of things:
1) A better place to check prices
2) Cost and complexity of upgrading to the single mass/RS style flywheel (does this require re-gearing and ECU re-program on a 97?)
I think I will get someone to help me check that the Check Valve is in correctly and that O2 sensors are functioning, any thought on other diagnostic stpes before taking a plunge on Top End? (Also i will try drive cycles again but at some point I need to fix this)
