993 Forum 1995-1998
ebrake install question
Old Jan 12, 2004 | 01:21 AM
FlyYellow's Avatar
FlyYellow
Default ebrake install question
I installed my aluminum ebrake today. I’m having a bit of the problem. The switch on the back that detects whether or not the ebrake is engaged or not doesn’t seem to make contact. In my car that’s actually a big problem because my top won’t go up or down without that switch.
There is some adjustment on the switch (i would describe it as an arc shaped adjustment), but it's not the arc shape it is just too far away. I tried to bend the ebrake side to be a bit closer but no dice. I attached some pics so you can take a peak for yourself. Any ideas????
In this second one i put the original ebrake handle next to the new one.
Old Jan 12, 2004 | 02:57 AM
DrZ's Avatar
DrZ
It looks like you already have the beginning of the problem I had as the copper contact appears to be torn near it's attachment to the handle. Be very gentle when reshaping because once creased and torn the piece will break completely off very easily.
Old Jan 12, 2004 | 03:13 AM
nels415's Avatar
nels415
I had this same problem with my aluminum ebrake and when I attempted to bend the contact, I almost tore it off, but I was able to save it by soldering it.
Old Jan 12, 2004 | 01:24 PM
ksjcorpus's Avatar
ksjcorpus
boris i have a cab and had the same exact problem -- i fiddled with it by bending the metal and broke part of it off but the contact seems to still be ok with the break pulled completely up.
Old Jan 12, 2004 | 10:52 PM
FlyYellow's Avatar
FlyYellow
what a pain - after about 3 hrs of fiddling i got it to work. hmmm. i've concluded that i hate microswitches....
thanks for al your help!
cheers,
boris
