993 Forum 1995-1998
Need AC lines diagram
Old Jul 18, 2018 | 08:20 PM
Hamid's Avatar
Hamid
Default Need AC lines diagram
My AC compressor was removed (?due to not working or to have more power) in any case, I wanted to reinstall a new compressor but need a diagram of where the hoses are. The 2 hoses that are normally attached to the compressor are obviously not present and I don't know what are where they are attached to when they leave engine bay and wanted to find out what else I might need to complete the work.
Old Jul 18, 2018 | 11:21 PM
BobbyT's Avatar
BobbyT
Hi Hamid,
If you go to this link, scroll down one page, select your model/year, and drill down to main group 8, sub group 13, illustration 813-30, you can see the diagram for the rear refrigeration circuit. The two hoses from the AC compressor run up across the top of the engine to the left rear of the engine bay, where they connect to two hard lines that go under the rocker panel to the LF wheel housing, where the receiver-dryer is located:
https://www.porsche.com/usa/accessor...originalparts/
For the front refrigeration circuit, go to illustration 813-25.
Old Jul 19, 2018 | 12:41 AM
nile13's Avatar
nile13
http://www.jackals-forge.com/lotus/9...e/ACdelete.htm
