Slow sunroof when closing
My sunroof goes back fine (opens), however when I go to close it, it closes at a very slow rate. This wasn't an issue until recently. I did some searching on here and couldn't really find anything conclusive. Before I unzip the liner and start digging into this, has anyone experience this or know of the fix? Thank you!
I had a very similar issue many years ago that would happen intermittently. Actually what I started doing was opening and closing it more often, lets say at least every time I drive the car. Somehow with that approach it hasn't happen again.
So am I hearing to drive it more? Oh yeah!
One can try shooting some spray oil base lubricant using an extension tube on the can into the tubes that the drive cables emanate from at the rear corners of the top. I suspect old dried lubricant along the length of the drive cables leading to the motor is the coulperate. Seeing the tubes may require some sunroof disassembly. I once serviced a 924s sunroof or identical design to the one on a 993, I seem to recall it wasn't that difficult to work on. In that case, the drive cable had pulled loose from the little side track car attached to the roof panel causing it to bind.
Andy
Andy
