XM Radio Install
As per requirements, I have searched the archives and found helpful info the XM radio BUT I did not find any photos of the small XM radio antenna mounted on and below the rear shelf....
Does anyone have photos they could post?
Also, if I want to stick with the OEM stock indash CD player....is there a way to input the signal without using a "sound quality degenerating" fm modulator?
Also, does anyone have any photos of where the stuck the LCD display and controller?
I am looking at the Alpine model
Thanks in advance...
Doug
Doug
Phlat Black Guru
Lifetime Member
- Times 2
Lifetime Member
- Times 2
1 Post
doug,
I have the xm with alpine head unit. My anteni is mounted under the below the rear shelf
Alpine is xm compatible. If you want stock you have to get the xm reciever
