LOW VACUUM & OTHER @$#@#
I had to work the entire weekend.
I used the boroscope to verify no holes.
After talking with a Porsche expert, he recommended take off the valve covers and look at the lifters rocker arms. You might have roken pieces.
I will do that leak down test Friday after my design review.
Update
I pulled the valve cover off and found the culprit, a non functional lifter.
I ordered new parts and the car should pull 11 in of hg at idle soon.
I plan to drive the car in stock form for about 1 month.
I will tackle the super charger again soon.
As for the split second box, I plan to use it as a clay pigeon.
It's been a long road, but the car is repaired and pulling a constant 12 in of hg at idle.
With that said, I am really to tired to put the supercharger back on today, so I will leave for another day.
I pulled a hose off the fuel pressure regulator on the intake manifold. You can pretty much take your pick for a vacuum reading.
Make sure the hose to the guage has a good seal.
FPR is on the fuel rail under the blower assembly, so if it's all the same, good to know I can find an easier access.
Cheers.
Seared
The supercharger is installed and it's pulling a solid 15 lb of hg.
Need to do some final checkouts, and I will take it for a drive tonight.
I will continue the updates in my TPC install tread
