recaro SRD's (bummer)
I just picked up a set of recaro SRD's with sliders and mounting brackets. I am bummed at how heavy they are. The SRD's with sliders & mounting brackets weigh in at 38lbs.
If the stock 993 seats weigh 49.5lbs (unconfirmed) then i'm only saving 11.5lbs per seat or 23lbs total. I keep reading that people are able to save 70lbs for both seats by doing this switch. What am I missing something?
I'm bummed!
My next step is to take out the factory seat and weigh it. If it truly only weighs in at 49.5lbs - well then the recaro's are going for sale.
Cheers,
Boris
I'm bummed!
Cheers,
Boris
Boris,
Sure the switch didn't involve the non adjustable SPG's? That would come pretty close to the weight savings you quoted. I assumed 14#'s per seat and 5#'s per slider as well, which, is probably a little heavy.
Regards
Andy
Regards
Andy
Boris, my 993 seats weighed around 48.5 lbs (22 kg) each, iirc. So your estimate seems reasonable, depending on number of motors in the seat, etc
The SRDs may be the wrong seat to get if weight reduction is your goal. The Recaro SPGs are more like 14-15 lbs each with sliders.
Boris - ditch the sliders...well at least for the drivers side. how often does anyone else besides you drive your car anyways?!?
the GT3 seats may be the best way to go (esp if cloth ones).
Thanks for all the comments. i guess i'm encouraged if my seats weigh 62lbs but discouraged if they weight 48.5 lbs. i'll probably pull the seats sometime this week. meanwhile i'll keep my fingers crossed - go figure who would hope that their seats weigh a lot. i have the 4 way supple leather seats in my car.
i can't go with the gt3 seats, simply because i need to be able to get my kids in the back. otherwise being the factory original snob i am - i'd be all over the gt3 seats.
i'll report back and post some pics....
cheers,
boris
cheers,
boris
Boris, I thought I was going to lose use of my back seats completely after I put the racing shells in. But with the slider in the fully forward position, my (adult) friends still manage to squeeze into the back and because the seat is so much shallower there is actually more legroom. It is not an ideal solution but it could still work.
For those contemplating changing out their stock seats for race seats, here is the trade off...you can install EVO seats or some such aproximation. I have the EVO 2 seats to accomodate my fat butt...but (no pun intended), these new lighter seats do not flip forward for access top the back, and they have almost 0 padding. Great for the track...but a bit on the uncomfortable side for the street. In addition, race seats make getting in and out of the car more of a chore. However the weight reduction and the addded feel for the car is great.
The up side, they weigh less and you don't slide around in your seat going around corners, and having the competition belts and sub strap coming through the seat seems to be the best way to go.
Boris, did you look at the new Cobra Misanos? They seem to offer what you are looking for . . . I've been thinking that if I replaced my seats, that would be what I would opt for.
Rennlist Lifetime Member
I have to completely agree with Martin - I recently removed SRD's from my track car and put in a set of Recaro race seats (Pro Racer SPG on driver's side & SPG on passenger's side).
The weight difference is major - I didn't weigh them it's significant enough that I can carry the SPG seats around the garage with just one hand; the SRD's were quite heavy.
I will say that I've done quite a bit of driving with the Pro Racer SPG and have found it to be very comfortable - I had two 200 mile trips and find it to be as comfortable as the SRD's were.
Well I took out the driver's seat and it only weighed it at 48lbs. It is a 4 way supple leather seat. So I guess I'm not doing the SRD's. oh well all that for nothing....
I need more ways to dump significant weight off my car!!!!
Cheers,
Boris
Cheers,
Boris
The SRD is far superior in holding a driver/passenger in the seat. However, i prefer the looks of the factory leather. I like the way the GT3 seats look, but quite frankly i need a seat that folds forward.
Boris
Boris
