Wobble at 60 mph
Sorry, I know this topic has been covered. I searched through past messages, however, and could not find the string where it was covered. My car has a wobble in the steering wheel around 60 mph. As I remember, the consensus was that this was caused by putting the lugs back on the wheels in the wrong order (i.e., the lug that needs the special key has to go in the right spot). Can anyone help me with this. Want to get wheels balanced tomorrow and thought I'd make sure it was done right. Thanks.
That's one thing to check, but you should probably get your wheels balenced at a high quality shop.
Any shop that has the Hunter 9700. This applies a load to the wheel to get a more accurate reading.
One last thing, check the torque on your bolts too. They should be 94 lbs/ft.
If you are in the Mountain View area, Custom Alignment has the Hunter 9700. I think that it cost $50 to have all 4 wheels balenced.
If you do a search for "Hunter 9700" in the old 993/996 archives, you will get a ton of hits.
Jeff
Jeff
Addict & Guru
Originally posted by Griffin Brown:
<STRONG>... the lug that needs the special key has to go in the right spot ...</STRONG>
Agree w/Jeff that the most likely cause of a speed specific vibration (wobble?) is wheel/tire imbalance. Might have lost a weight, etc.
![](https://rennlist.com/forums/images/ranks/veteran_army.png)
I second Jeff and KC about Custom Alignment and the Hunter 9700. I have 18" wheels, and Custom got the balance right the first time after two other independents had failed with the wrong equipment.
Had the same problem (@60mph) & had them dynamically balanced. HUGE difference. Smooth up to 100+. My only complaint was the method used when the shop put the wheels back on - air wrench.
FWIW, the wheels are 17" cups.
Hey Griffin...
It's a slow day at work, so I did some archive searches for you...
check your wheel balence...
New Rotors made the difference... Hunter 9700 Wheel Balance - the only way!
993S Wheel balance/warped rotors?
Wheel Balance/Alignment shops in Bay Area?
Re: road force measurement
Enjoy!
Jeff
Enjoy!
Jeff
