Innovate LC-2 and ECU Sensor Ground?
It's unfortunate that you went thru all that effort, when your DME ECU could have been repaired for about 1/3 the cost of the estimate you received.
Furthermore, you are aware that from a functional standpoint, that the O2 input on the '95 Bosch ECU just utilizes input voltages greater or less
than .50 volts to control the mixture, i.e. there's no benefit from using a wide band O2 sensor.
I'm curious... Are you logging the wideband sensor data, or using it in real-time just to monitor the AFR? The former would be useful for having a custom map made by someone like Wong or Wiener; but, what it the purpose of monitoring the AFR in real-time?
I was quoted $900 by ECU Doctors in FL, if you know of somebody who would fix for less, why don't you post it so others can benefit? The Innovate unit relies on a wideband O2 sensor and provides two outputs: a wideband signal (which I connected to a wideband gauge for a much more accurate AFR read than a narrowband would provide), and a programmable emulated narrowband signal (which I connected to the stock narrowband Motronic ECU). What do you think would happen if the wide band signal was used as input by the ECU?
Ivan provided (up-thread) an explanation to your question about using a wide O2 as an input to a narrow band ECU design, as I did in post #15.
