OBD II Code Help
Anybody have any ideas of what this means or how to keep it from recurring?
I did have the RS flywheel and clutch installed over a month ago, but I wouldn't think there would be any correlation.
One more question: What is the correct procedure for a "trip drive cycle"? Just taking the car out for a drive or is it a certain procedure i.e. specific time at certain revs/gears?
Thanks for your help. Subscribing to this board is money well spent!
Dave
Not exactly sure, since my experience with camshaft position sensors failing is not on my p-car, but it likely means the cam position sensor needs to be replaced.
You didn't say if your car runs ok or not, but I'm assuming it's currently running. In that case the cam position sensor is not completely dead. When they go completely, the car's computer can't keep accurate timing, and the engine usually doesn't run.
Best bet is to have the car checked out by your mechanic. FWIW, problems with the CPS aren't something I've seen on Rennlist before (not that I'm an old-timer here either).
You're right, the flywheel/clutch replacement should be unrelated, unless the CPS was crunched or something during the process.
Drive cycle info is in the archives. It's a lengthy process, and I don't remember it all offhand.
-Chris
Thanks for the reply. I didn't even know there is a camshaft position sensor. I will have my mechanic check it out. Did a search for drive cycle and came up with the list. Sounds bizarre, but I will give it a shot.
Thanks,
Dave
There may be a fault, but I would want to to replicate the problem and check all the other systems before changing parts. Clear the code and drive the vehicle again, see if the code re-appears.
Hate to sound stupid, but what is the CMP? You mention it is in the ignition distributor.... I did have the distributor belt changed as well as new cap and rotors when the engine was out. Could this be related?
The car is running great.
Thanks,
Dave
Pull the caps and see if you can rotate the lower rotor by hand, if so, you need to have that repaired ASAP.
Porsche sells a rebuilt (just a new belt) distributor for $ 800. FWIW, we can replace the belt in your distributor for $ 170, complete.
because of a problem in the ignition wires/connectors. Obviously, check the
connections from the sensor to the DME (pins 53 & 21), but also check all the
engine grounds.
It does seem strange that this problem occurred shortly after a clutch job.
Good Luck
Loren
'88 3.2
Yesterday while stuck in road construction on a 95 degree day, right about the time my oil temp gauge went above the 9:00 position, my car threw a P0341 code.
I have no record of distributor belt servicing in my car's 126k mi life (on my list along when wires/plugs are due in 6k miles) . So, I followed Steve's advise above and tried to spin the lower distributor rotor. I cannot spin it, however, it does "wiggle" a little. Maybe an 1/8" of a inch to the right. Is this wiggle normal or should the rotor be completely locked in place?
Thanks,
Matt
It was definitely not locked in place. So you aren't alone. No codes though...
Thanks,
Matt
I've cleared the code and been out just enough to get the car up to temperature twice now. It has not thrown the code again. I cannot detect any other symptoms, but I'm a rookie here.
For the time being, I'll chalk it up to caps/rotors/plugs/wires all nearing the end of their service life. Let's hope it doesn't come back until closer to winter when I had planned the major ignition system maintenance anyway.
Good news is that the P0341 has not returned. Fingers crossed it was a random issue that may or may not have been caused by excessive heat.
I'm trying to avoid the "shotgun" troubleshooting approach and willing to invest in some time to get to the bottom of this.
I presume I need to get more data, so that means a PST2, Hammer, or UDT999/PDT999. I'm leaning strongly toward the UDT999. Does this seem like a reasonable next step? What data should I be looking for?
PS. At this point, I'm ruling out the durametric, because it doesn't support the ABD bleed procedure that I'll need every year or so. (lucky me, my car as the ABD).
In this case, however, I'm not convinced that a scan type of tool will help you.
Search the digital version of the 993 workshop manual for "hall sender".
The workshop manual lists an oscilloscope as the tool to verify that it is operating properly.
You might want to check on the price of a new hall sender.
I have a receipt somewhere that shows my hall sender (sensor) was replaced at some point, prior to my ownership.
Sometimes a code will point right to the problem, sometimes it is a reflection of a different problem.
Knowing other engine data may help. Hard to say for sure... The engine might be running poorly because of the (possible) hall sender issue and the data that the tools can gather may not help you because everything is off because of the (again possible) hall sender issue.
Hey, trying to help you think through this. Keep us posted.
My guess is that I need to tap into the DME (still unsure how to do this) and measure a voltage change over time using the oscope.
I'm assuming:
1) the MIL is triggered by x sensor sending/not sending y value over z threshold n number of times
2) The real code reader (Hammer, PST2, etc) can confirm x. My crappy code reader is just showing generic trouble code. Unsure if I should consider this confirmation that x = hall sensor.
3) The oscilloscope can confirm y (voltage over time). Assuming there is a voltage peak every time the distributor completes a revolution
4) z and n are unknown and programmed into the DME (can't seem to find in the WSM)
So, to confirm the hall sensor fault and not some other ignition problem, I need to confirm x, and measure y, hoping to see y hit/miss some unknown exceptional value under some unknown intermittent condition. Ugh. Please tell me there's a better way ;-)
