Caliper rebuilding costs
Just exploring rebuilding my 993's calipers as part of preventative maintenance after recently completing this project on my BMW track car.
Looks like seals, dust boots, and bleed screws will be $700-$800 if I source from a discount Porsche retailer like Sunset.
Aftermarket (let's say racingbrake) is less than half that or ~$300.
For those that have done this before:
1) Assuming no visible damage to the originals, is there any reason to replace the retaining clips and spring plates?
2) Is there any performance advantage to going with original Porsche parts here? Aftermarket is significantly cheaper.
3) Anything I'm missing here (assuming the pistons are in good shape)? $300 to rebuild all 4 calipers seems like it's too good to be true.
Seared
When I rebuilt my calipers a few years ago, I purchased 16 Brembo kits from Sunset. Each kit included a piston, a wiper seal, a dust boot, and grease. At the time, I believe I paid somewhere around $300. This after buying aftermarket seals first and immediately returning them.
Caliper rebuild
Andreas
Caliper rebuild
Andreas
2) You get what you pay for - I purchased OEM bleed screws and the like from Sonnen
3) Beer - it's a pig of a job cleaning
Good luck, and have fun with it!
Can't help you with prices at the moment, but I used EBS to source my caliper parts. I did not replace the pistons, since mine looked perfect. Just went with new seals, boots and bleed screws.
If the brakes have been properly maintained over the years, then there shouldn't be any rust on the pistons or caliper bores and a simple seal swap will restore as new performance.. You never know until you're in there. If you can afford the down time then start with rubbers and buy the other parts as needed. For a guaranteed win, replace everything at once.
I'm a stickler for OEM parts. There's just too many factors involved in compatibility matching and material qualities that I want the peace of mind knowing that many smart Porsche engineers made sure everything will work as intended.
Watch out if you sand blast or media clean the parts. There was an Excellence/Panorama article a while back about a brake job gone wrong. Just like oil journals, they're difficult to properly clean and you can imagine what ground walnut shells in your brake fluid
Seared
Prices from the usual discount retailer are:
4 x front 36mm kit - 95135191910 - 31.64 each
4 x front 44mm kit - 92835191910 - 37.34 each
4 x rear 34mm kit - 96535291910 - 43.75 each
4 x rear 30mm kit - 95135291911 - 51.06 each
4 x bleed screw set (pair) - 93035191900 - 16.89 each
Total: $722.72. Not bad, but still on the hunt for brembo dust boots + square cut seals. Will follow up if I find some way to get these 32 little pieces of rubber for a reasonable price.
Technical Guru
The go-no-go for the spring plates is a question of how difficult is it to insert a brand new brake pad? You can getaway with filing down the edges of the pads a few times but eventually you'll want to replace the plates, usually during a repaint. Definitely take a set of dental picks and clean out all the corrosion and pad dust from behind the plates. If you make a point of cleaning behind those once every year or two then the spring plates will never deform enough to prevent the pads from moving.
