Alarm sensor
Alarm sensor
I have a early 1995 993 with a red alarm light on the driver and passenger door that does not light up. I took out the red light and tested it, which tested good. I connected everything back together and locked the car, but no blinking red light. Any suggestions?
The alarm indicator LED's are controlled by the alarm/door lock control unit.
Did the passenger door lock as expected when you locked the car? If not, your alarm control module might have given up the ghost, or its fuse has blown. The fuse is placed between the two control module connectors, placed under the passenger seat.
Cheers,
Tore
Cheers,
Tore
If both door locks operates electrically when turning the key in the lock, the alarm/door lock control module is working.
If so, you might have a wiring problem on the circuit for the LED indicators, or maybe the LED output on the door lock control module is shot for some reason.
Here's a forum thread with some more details: https://rennlist.com/forums/993-foru...-easy-fix.html
Cheers,
Tore
Cheers,
Tore
Thank you Tore........so, diffently not a fuse? It’s going to be something in the module then? Your best guess on why the red door lights don’t work?........im just trying to narrow down before taking the seat out......thanks again
You may have already found this thread - but if not, it includes info for tracing the signal back to the control unit connector.
Or, maybe I'm thinking of the immobilizer, which your car does not have... maybe I'm just getting old.
I defer to Tore, who has forgotten more than I'll ever know!
