pp000830
close
- Join DateJul 2004
- LocationDallas, TX
Liked:2,057 Times in 1,422 Posts
CAS #: 64742-47-8, Low odor paraffinic solvent. Dearomatized kerosine. Deodorized kerosene. UN #: 3082 (see Notes). EINECS #: 265-149-8. ACUTE HAZARDS, PREVENTION, FIRE FIGHTING. FIRE & EXPLOSION, Combustible. Above 66°C explosive vapour/air mixtures may be formed. NO open flames. Above 66°C ...
So I guess all one has to just use is a liitle kerosine to avoid parafin wax from gunking up their fuel system.
Others thoughts?
Others thoughts?
No thoughts of my own but heres Mike's counter
MYTH #4: “STA-BIL BRANDED PRODUCTS ARE JUST KEROSENE.”
Here’s our official answer, direct from Chief Chemist and V.P. Of Product Engineering Mike Profetto:Quote:
“STA-BIL brand additives use a highly-purified petroleum distillate to deliver our additive package to the fuel. This solvent allows the additives to quickly blend completely into the fuel. The additives themselves would be too concentrated to blend easily, especially in cold weather. Use of more flammable solvents like gasoline would make shipping and storage too dangerous. The addition of the recommended dose of STA-BIL product to fuel has always been safe. Dozens of Original Equipment Manufacturers (OEMs) have confirmed this by testing and recommending our products.”
pp000830
close
- Join DateJul 2004
If so what other components are in it that are not listed on the Government mandated MSDS sheet??Originally Posted by Grapeape
No thoughts of my own but heres Mike's counterMYTH #4: “STA-BIL BRANDED PRODUCTS ARE JUST KEROSENE.”Here’s our official answer, direct from Chief Chemist and V.P. Of Product Engineering Mike Profetto:
I'm reluctant to call information the manufacturer themselves submitted to the federal government a "myth".
The above reply technically doesn't disagree with my initial assertion.
Please educate me??
pp000830
close
- Join DateJul 2004
From the MSDS Sheet:
100.0 % CHEVRON TECHRON Concentrate CONTAINING COMPONENTS AMOUNT LIMIT/QTY AGENCY/TYPE SOLVENTS INCLUDING: >
20.00% SOLVENT NAPHTHA, LT. AROMATIC Chemical Name: SOLVENT NAPHTHA, LIGHT AROMATIC CAS64742956 NONE NA (also known as white gas or Colman lantern Fuel)
STODDARD SOLVENT Chemical Name: STODDARD SOLVENT CAS8052413 100 ppm ACGIH TWA 2900 mg/m3 OSHA (Genericall known as Paint Thiner)
PEL HYDROTREATED, DISTILLATE, LT. Chemical Name: DISTILLATES, HYDROTREATED LIGHT CAS64742478 NONE NA (another Name for Naphtha above)
TRIMETHYLBENZENE-1,2,4 Chemical Name: BENZENE, 1,2,4, TRIMETHYL CAS95636 < 8.00% 25 ppm
ACGIH TWA XYLENE Chemical Name: BENZENE, DIMETHYLCAS1330207 < 3.55% 100 ppm ACGIH TWA 150 ppm ACGIH STEL 100 ppm OSHA PEL 100 LBS CERCLA 302.4 RQ
CUMENE Chemical Name: BENZENE, (1-METHYLETHYL)- CAS98828 < 1.50% 50 ppm ACGIH TWA 50 ppm OSHA PEL 5,000 LBS CERCLA 302.4 RQ (cumene is consumed as a chemical intermediate in the production of phenol and acetone, two chemicals used to make plastics.)
pp000830
close
- Join DateJul 2004
Quote:
That is the last one, I've spent all my fluids for the moment.Originally Posted by Quadcammer
seriously, did we really need another thread like this
Geez, dude, you gotta get a hobby. Or learn how to use a dictionary or spell check.
ExploreRennlist Member
Mark in Baltimore
close
- Join DateMay 2002
- LocationBaltimore, MD
Liked:511 Times in 327 Posts
Merging these two fluid threads. Arguably, neither of these threads should be in the 993 forum, but I'll leave them here for now.
max911
close
- Join DateJul 2002
- LocationCanada - West
Liked:235 Times in 94 Posts
I've been upset since they changed the formula from BENZENE, 1,2,4, TRIMETHYL CAS95636 < 8.00% 25 ppm to BENZENE, 1,2,4, TRIMETHYL CAS95636 < 8.00% 20ppm.
I now add an eyedropper of triple distilled Vodka to each tank. Condition of the top end components next engine tear down should prove this was the right move. YMWV.
(Your Mileage Will Vary)
Seems like a waste of good vodka.Originally Posted by max911
I've been upset since they changed the formula from BENZENE, 1,2,4, TRIMETHYL CAS95636 < 8.00% 25 ppm to BENZENE, 1,2,4, TRIMETHYL CAS95636 < 8.00% 20ppm.I now add an eyedropper of triple distilled Vodka to each tank. Condition of the top end components next engine tear down should prove this was the right move. YMWV.
Quote:
much better use of time/energy, than it took to read this thread. :-0Originally Posted by bobboinski
C'mon man!
