993 Splitter ID
The fever I speak of, it's the old, "add front splitters" then mull over all the internet advice you'll get about the car being unbalanced. This is total BS, all the RS splitters do is reduce a little lift, they provide 0 downforce. According to the 993 RS/CS Porsche Factory Bulletin WKD 499 620, Section 5, page 2.....at 270 KPH, the "FA lift in Newtons" is 178. If the number is positive as is the 178, there is no downforce.
The next part of the syndrome, with front splitter, "I need to buy a 993 RS tail". The tail will produce down force at the 0, 3, 6 and 9 degrees of down angle, -119 (-25 Lbs), -297(-67 Lbs.), -535(-120 Lbs) -713(-161 Lbs) Keep in mind that these numbers are wind tunnel derived, at 270 KPH, or 162 MPH. Lots of luck getting to 162 MPH with a wing at 9 degrees of down angle and a stock 993 motor putting out 260 HP to the rear wheels on a good day.
I have been through Turn 2 at California Speedway with a stock tail 993 (scary), a 993 RS tail (marginal) and a 964 3.8RS tail with a 60" Crawford wing, with end caps and a Gurney lip (awesome). I also had 993 RS CS front splitters and 993 RS side skirts mounted up with the Crawford wing I got from Jae Lee at Mirage International in San Diego. Now here is where I eat some "Crow", I couldn't find, nor could I afford OEM 993 RS CS front splitters, or an OEM tail, pretty much NLA, so I went to Gert for a 993 RS CS knock off, Getty Design for the tail base.
When the car was in an earlier iteration as a 993 RS (clone) I used factory front splitter and side skirts with a Getty Design tail***. I was too cheap to spend the added bucks for the OEM tail. I wish I had...because when it was time to sell the after market tail I took a beating...which would NOT have been the case with a OEM tail. ***I also tried aftermarket (Not referring to Getty here) the fit and finish, and overall quality was poor to mediocre. My buddy bought one of these aftermarket tails, his painter spent 9 hours prepping it for paint.
But here is what I do know, and you can take this to the bank. Always buy OEM in contrast to aftermarket. It fits better, lasts longer and retains its value. The reciprocal is gospel truth with aftermarket. I have been down this road too many times, and its always the same scenario. Yes I saved money and sacrificed quality on the front end, but lost big bucks on the back end. Originality on parts is its own reward.
Yes, OEM will cost more, but it's worth more, it retains the panache of Porsche authenticity, and speaks volumes about your taste and values. And luckily, the original 993 RS OEM is available, for how much longer I don't know, from Gert at www.carnewal.com He operates out of Belgium and has an impeccable reputation, been selling to us Rennlisters for 20 years, more of less. I never hesitate to buy from Gert, nor should you.
Also, thanks for the link! I might be ordering sooner than later.
I've had the RS splitters from GT3 on my 95 C2 for 4 years now. They fit perfectly (I installed them myself after getting them sprayed) and they have worn very well. When i get bored of the look I'll put the stock ones back on.
Yeah, I actually don't mind the look either but I want to see this piece in person. I think it add's a little something to the back without taking away from the shape of the car too much.
A somewhat analogous situation exists with OEM parts VS used parts, but on a much smaller scale. Example, I bought a set of 993 RS splitters...decided to go another direction later on, sold them fro nearly what I paid for them. I have sold aftermarket tails and take nearly a 60% hit....OEM for me.
But here is what's going to happen when you buy the cheap ones...every time you look at the car, you'll know that for a few bucks more, you could have had the real deal. Sure the ones from XXXX in San Diego are cheap..but you get what you pay for. Save a few more pennies over the next few months...pass on Starbucks Veinte in the AM with a pastry. In a few short months, you'll have lost 5 + lbs and you'll have the money for a genuine OEM part.
