993 Forum 1995-1998
rough transmission
Old Oct 26, 2002 | 03:13 AM
FlyYellow's Avatar
FlyYellow
Post rough transmission
hi folks,
i have a '95 993 and the transmission seems to be a bit rough.
Problem: When shifting from 1st to 2nd it tends to grind just a bit.
I checked the linkage and that seems ok. Would anyone have any other recommendations. I was thinking of draining the tranny fluid and replacing it with synthetic.
Any other ideas?
Cheers,
Boris
Old Oct 26, 2002 | 12:22 PM
bet's Avatar
bet
Post
Boris,
Does the grinding only take place when the transmission fluid would be considered "cold"? Does it then stop or at least get much better after things have reached operating temperatures? If so, this is typical and considered normal. Robin has a write up on his web site about his attempts to get rid of this problem with different transmission fluids and the varied success he had. Double clutching will eliminate the problem.
If the problem is more persistent than the 1-2 shift when cold then your sychros are probably getting worn.
Old Oct 26, 2002 | 12:50 PM
FlyYellow's Avatar
FlyYellow
Post
Brian,
It does appear to go away once the car is warmed up. I'll look for Robin's site and see what he found. It is typically the shift from 1st to 2nd.
Cheers,
Boris
Old Oct 26, 2002 | 01:49 PM
FlyYellow's Avatar
FlyYellow
Post
I couldn't find the page on p-car.com can anyone post the link for me.
Cheers,
Boris
Old Oct 26, 2002 | 02:04 PM
Jeff 993TT's Avatar
Jeff 993TT
Post
Is it this link?
<a href="http://p-car.com/diy/transmissionfluid/" target="_blank">http://p-car.com/diy/transmissionfluid/</a>
Jeff
