993 Forum 1995-1998
Brake Bleeding 96 C2
Old Dec 15, 2003 | 05:18 PM
GrantG's Avatar
GrantG
Default Brake Bleeding 96 C2
I have a Motive power bleeder and I'm pretty experienced with using it (but never on my 993). I've read various info about needing to bleed a special ABS valve as well as the 8 caliper bleed valves. Is this only necessary if I'm flushing the entire system only (can I just bleed the calipers if I'm not going to do a complete flush)? Is it necessary to bleed the clutch at the same time as a complete flusing of the brakes?
Many thanks!
Old Dec 15, 2003 | 05:35 PM
Greg Fishman's Avatar
Greg Fishman
Grant,
Do a search this has all been covered many, many times.
Old Dec 15, 2003 | 05:51 PM
Rick Lee's Avatar
Rick Lee
Grant, I have the same car and have bled my brakes several times. Always do the clutch, as long as you have it all hooked up. You just need to do the 8 calipers nipples and the one clutch. That's it.
Old Dec 15, 2003 | 05:56 PM
GrantG's Avatar
GrantG
Thanks!
Old Dec 15, 2003 | 10:50 PM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
He said nipples
Old Dec 15, 2003 | 11:00 PM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Good advice,....
You do not need the Hammer to bleed brakes unless you run the ABS unit dry.
