Gnarly Distributor Innards
Was replacing spark plug wires/plugs/cap/rotors and found this craziness in my distributor!
I was just planning on DIY'ing the belt, but now thinking of sending off for full rebuild to see where the peanut butter came from... geesh
Anyone seen this before?
Mmm, peanut butter n corrosion...with a second helping of corrosion!
Apparently, moisture got into the distributor at some point.
Depending upon how deep the corrosion goes, I might look to find a good used body and rebuild it with your parts.
Distributor body is aluminum so can't rust. That is rust from other stuff. I would remove and send to get disassembled, inspected, and freshened up as necessary, including belt replacement.
Your are not supposed to go swimming in your car!
The distributor should have been at least lubricated with a little oil on the sponge in the center shaft. It looks dry. Clearly no one has been servicing this distributor for quite a while. Could the water egress be due to the vent hose on the side of the directly driven distributor falling out and then rain or road splash getting inside the opening?
I have had the experience of it coming loose as the plastic vent hose fitting that holds it in is not very robust.
I did find the vent hose disconnected at some point, suspect that must be the source of water intrusion. Amazing.
Steve... any Black Friday specials going on at Rennsport for peanut butter flavored distributor rebuilds
I got 100,000 miles out of my dual distributor and the belt, having it pulled for service even though it was still working properly.
I attribute this long service life to oiling the internals under the dust caps/insulators at the base of the rotor shafts every two or three years when I replace the caps and rotors.
When I finally had the thing rebuilt the only bearing that needed to be replaced was the bushing under the little gear drive. My opinion is that eventually the two large bearings, one under each rotor can run dry and fail over a very long time so keeping things wet with a little oil may have contributed to their extended life on my car.
RL Technical Advisor
No Black Friday specials, however I can rebuild your distributor so its as good as new.
Just a quick update... Thanks to Mark Cohen near Atlanta, GA, all the peanut butter is cleaned out and car is running great!
Mark did the work and had it back in the mail in only a couple of days...Thanks Mark!
