Installing Rear Fog light switch
Has anyone come across a factory like solution for adding the rear fog light switch, specifcally I'm referring to the connections at back for power/ground/etc.?
Im pretty sure getting a orig factory connector is near impossible so i'd take an insulated connector that would mount to the solid pins that are on the back side of fog light switch, but not sure where to look for such a solution.
thanks,
Rob
thanks,
Rob
