Cab top locking motor manual screw not engaging
Hi everyone,
a few few days ago one of my locking motors had a senior moment and decided not to disengage all the way. I tried manually locking down the top using the manual screw and was not successful. It appears that the screw is not moving in at all as a rotate it which is making it impossible to either secure the top or manually lower it. Any advice would be appreciated because I see no other way to fix the problem than that screw. Cheers!
Tom
Tom
I sat for about an hour screwing it in and it never appeared to go in at all. If I am unable to use the motor or that screw I'm completely lost with how I can open the top or secure it fully (dash light goes out).
I was able to get the top open randomly trying it one time while pushing up and down near the locking motor. I tried to lock and unlock the top several times, which it will do successfully. Sometimes. Other times it gets caught and there is a loud pop that doesn't sound great obviously. When looking into what has to be the most difficult screw tunnel known to man I can see that the screw is being rotated by the motor whether it successfully lock/unlocks but the screw remains in the "popped out" position. Any thoughts or ideas would be appreciated, thanks again everyone!
