I run a set of OEM MY02's on my WB C4S. I can't recall the offsets, but spacers are needed on the rears only. I run 32mm spacers and have had no problem with them after 7 years
Yup, WB's typically run 40 offset in the rear so 25mm spacers would bring the MY02's with 65 offset back to spec. 32mm will provide more poke, and apparently clear fine
MikeJ runs a set on his TT periodically throughout the year, he actually has them on now. So I'd shoot him a msg if you'd like to see how a set will look on a WB with spacers. Tlaloc is spot on about the tires too.
Excellent. Tku.
Originally Posted by u7t2p7
MY02 only come with 50/65 offsets. NB/WB have same front so no spacers required in front. Rears only as per Goofy.
Great data. Tku.
Originally Posted by Tlaloc75
The slopping may have more to do with your tires than your wheels
Try a set of summer tires (re71r is popular right now) and you'll feel a huge difference vs the DWS 06.
Yep. I am sure. That is the case. I'm looking at PS's as well.
Excellent Tku.
Yes - so I'll jump to 18" and new tires. It's time.
Originally Posted by goofballdeluxe
Here's a photo with them on:
Nice. Looks great.
QUESTION: Does BBS make MY02's as well if I were to purchase new?
[B]Considering that the wide body off-set was an et. 40 on the rear of a 10"wide wheel this would then kick out the et. 65 with the use of a 15mm spacer.
Somethings not right with the math. 40et plus a 15mm spacer only gives you 55et not 65. As mentioned earlier by Foxman and Goofball it requires at least a 25mm spacer to reach a 65et.
Wheel Dynamics is number one for their wheels, not their math. By the way, I miss the bonde on the old avatar.
MY 02 wheels are awesome. Incredibly light and easy to clean. You can buy them new from Gert at Carnewal for about $3,500. http://www.carnewal.com/products/P93/p96031/MY'02-Wheels
Sorry, yes, I stand corrected... trying to do too much at once...
