Clutch replacement
Order the 993 RS Lightweight Flywheel and clutch...it will not fail. Some say that the 1995 cars are subject to stalling with the RS LWF..if you are concerned about this, ANDIAL in Santa Ana, CA sells a LWF withy some weight added.
Regardless of which way you go, the engine will spin up a little faster. The trade off, with the clutch out, in neutral, go will hear the gear sets rattling around...it is not so bad.
Steve Weiner at Rennsport in Portland, CA sells the 993RS flywheel and clutch without weight added. He may also have the weight added variety.
Good luck with the project.
