993 Forum 1995-1998
Installed my V1
Old 05-31-2004 | 09:15 PM
  #31
Livefreeandrive's Avatar
Livefreeandrive
I tried a new two connector antenna for my xm radio on my rear deck. My V1 went berserk displaying a full Ka signal full time. I went back to old antenna which does not work well inside car. I think I am going to rip all that crap out and put it in my suburban. Does anybody have any external xm radio antenna solutions??
Old 06-01-2004 | 12:01 AM
  #32
Phil's Avatar
Phil
Phlat Black Guru
Lifetime Member
- Times 2
When I had xm installed last year, the installer put the antenna on top of the rear parcel shelf......V1 went berserk!.....moved the antenna under the shelf.....and all is good !!
Old 06-01-2004 | 12:14 AM
  #33
Livefreeandrive
Does under the shelf mean under the leather between the rear speakers?
Old 06-01-2004 | 12:18 AM
  #34
Phil's Avatar
Phil
Phlat Black Guru
Lifetime Member
- Times 2
yep
under the rear speaker shelf...
Old 06-01-2004 | 02:15 AM
  #35
KM's Avatar
KM
What if you have a tach with the computer display as the Turbo does - can you still mount the remote display on the steering column? Will it obscure the computer display?
Rob,
You cannot mount directly in front of the tach without blocking the display. I put mine bewtween the tach and speedo and it works just fine.
Kevin
Quick Reply: Installed my V1
