992.2 C2S gear oil 150 ml extraction
Old Jun 11, 2026 | 09:51 PM
karts51's Avatar
karts51
8th Gear
Default 992.2 C2S gear oil 150 ml extraction
Anyone know if 150 ml of gear oil needs to be extracted like the procedure for the 991 gt3? Can't find a DIY on 992 Carrera gear oil anywhere.
Old Jun 11, 2026 | 10:00 PM
detansinn's Avatar
detansinn
It’s an 8 speed PDK, so no. Why are you doing this? The interval is like 12 years or 112k miles.
There’s absolutely zero reason to mess with a working PDK transmission and nearly every 992.2 is still under warranty.
Old Jun 11, 2026 | 10:12 PM
karts51's Avatar
karts51
8th Gear
Not doing the PDK, just the diff oil (Different oil in a separate reservoir). No filters in the diff and they will produce metal during break-in. Seeing 991.1 gt3 DIY's that have people extracting 150ml. I don't have a PIWIS account so have no clue where to get info on this car.
Old Jun 12, 2026 | 12:09 AM
Icegrill's Avatar
Icegrill
No one’s extracting anything from a brand new car. This isn’t a Toyota 4 runner needing its break in service.
Old Jun 12, 2026 | 12:22 AM
karts51's Avatar
karts51
8th Gear
Haha to each and their own. Oil analysis would disagree tho. An engine and diff up to 1,500 miles produces about 10x as much metal per mile than any other time in the cars life. I’d like to drain my diff since I’m keeping this car for a long time.
Old Jun 12, 2026 | 01:25 AM
kayjh's Avatar
kayjh
By that rationale, why don’t you do the pdk and the engine. Don’t they have metal parts that will wear in and produce metal bits? You know there are filters fitted, don’t you?
Old Jun 12, 2026 | 01:40 AM
Icegrill's Avatar
Icegrill
You’re not going to get an answer because no one in their right mind is messing with these modern transmissions,
Old Jun 12, 2026 | 01:45 AM
karts51's Avatar
karts51
8th Gear
I have. I changed my engine oil at 500 and 1,500. Doing it again at 2,500. The filter only gets the big pieces. All the 2.5micron grit keep grinding. PDK / DCT clutches don’t produce as much metal and have filters, so that oil can go much longer. Blackstone has shown that in higher mileage cars.
diffs have no filter and produce metal. My F80 M3 even had a mandatory diff service at 1,200 along with oil. Just because Porsche says go drive 10k miles on a new engine doesn’t make it a good idea, they just need the car to last a warranty period.
Old Jun 12, 2026 | 01:51 AM
karts51's Avatar
karts51
8th Gear
The transmission is a bit of a pain because it has a fill mode, pan and a narrow temp range for filling.
The diff is an easy DIY with the service manual and a syringe. Engine oil also takes me about 30 minutes and only costs me $75, so why the heck not.
Old Jun 12, 2026 | 06:47 AM
Fullyield's Avatar
Fullyield
To directly answer your question, no one has posted a transaxle, differential or MT gear oil change DIY tutorial for either the 992.1 or 992.2. The last one posted was for a 991. You might want to check the 991 forum.
Old Jun 12, 2026 | 07:00 AM
Fullyield's Avatar
Fullyield
He is talking about the transaxle or differential and gear side (not clutch side) of the PDK transmission (which is a MT gear set). Neither of these have filters. That’s the point. Many experts recommend changing GEAR OIL (not PDK clutch oil) first time at 10-15k miles to get the metal fine from break in out and then follow the owner’s manual recommended service interval after that. To his point, this is what a magnetic rear differential drain plug looks like at 10,000 miles. I understand why he wants to change it.
Old Jun 12, 2026 | 07:35 AM
detansinn's Avatar
detansinn
I did a spittake reading this. It’s totally unnecessary to change oil this frequently with these cars.
The factory recommended oil change interval for these cars is 20k miles for most of the world. It’s 10k in the US, because PCNA can’t get Americans to think in those terms. A 911 is not a fragile thing.
Old Jun 12, 2026 | 07:53 AM
Fullyield's Avatar
Fullyield
Any personal derogatory or demeaning comment directed at another RL member should be deleted by a moderator. Ohh, you are a moderator? You are entitled to your own opinion as is he. But your personal attack is unprofessional, especially for a “RL Community TEAM Member”.
Old Jun 12, 2026 | 08:15 AM
detansinn's Avatar
detansinn
This was fixed. No derogatory intent.
Old Jun 12, 2026 | 12:19 PM
karts51's Avatar
karts51
8th Gear
These insanely long maintenance intervals are driven by environmental policies, not oil analysis..
Look up Lake Speed Jr. from Speed Diagnostics.. He’s done tech talks for PCA and has piles of data that 100% support a couple early oil changes along with gear oil. Porsche wants you to get thru the warranty and doesn’t care if your rod bearings and compression is crap at 160,000 miles.
