Can this tool be recreated with Home Depot tools?
Old Feb 4, 2026 | 10:15 PM
  #46
RotorOver's Avatar
RotorOver
Veteran: Navy
Funny this should come up when it did as Matt from Obsessed Garage just did a piece on the Hytorc that he sells. About 11:15.
Old Mar 17, 2026 | 05:20 PM
  #47
sk911's Avatar
sk911
Someone is selling a slightly used Renntorq V2 in the Marketplace at a pretty decent price...$1650...no affiliation, just passing along the find!
Renntorq V2 center lock tool - Rennlist - Porsche Discussion Forums
Old Mar 17, 2026 | 07:31 PM
  #48
2023PythonGTS's Avatar
2023PythonGTS
Originally Posted by ace10
Sure it'll remove the wheel. As would any decent 1/2" or better uggadugga. But then what? How do you reliably achieve the 450ft lbs to reinstall?
The fastening is the critical part of the process.
48” Torque
Old Mar 17, 2026 | 08:29 PM
  #49
malba2366's Avatar
malba2366
Originally Posted by Bluehighways
The highest torque electric drill presently available is "only" capable of 1,400 in/lbs (1,400/12=117 ft/lbs). The torque on a Porsche Center-lock is something like 442 ft/lbs. You'll need a really well made 4:1 planetary transmission just to get close to what is needed.
This won't work because there is no way to precisely regulate the amount of torque from an electric drill or driver.
Old Mar 18, 2026 | 04:10 AM
  #50
Nein Eleven's Avatar
Nein Eleven
No one has made fun of the Makita and Ryobi guys on the first page yet? Is this Rennlist or did I stumble into the wrong forum?
Old Mar 18, 2026 | 07:33 AM
  #51
dlaunde's Avatar
dlaunde
For my understanding, if using something like the RennTorq, when putting the CL back on, would you set your torque wrench to 95ftlb?
Old Mar 18, 2026 | 01:26 PM
  #52
cutlass476's Avatar
cutlass476
Veteran: Navy
Originally Posted by Holger B
Maybe this has been covered ad nauseam...I wonder how many tire shops have the tools to remove center locks to fix a flat? Do owners always have to carry all that gear around just in case?
My local Discount Tire has the equipment (breaker bar and long torque wrench) to remove/reinstall CL's. You will still need you CL socket from the frunk. I still do it myself. I remove all four wheels and then take them in to mounted and balanced or I have a mobile tire service come to the house. I remove/reinstall the wheels myself either way. I don't need the hassle of some dude dicking it up and banging the side of my car with a breaker bar or torque wrench.
Old Mar 18, 2026 | 01:30 PM
  #53
cutlass476's Avatar
cutlass476
Veteran: Navy
Originally Posted by Kalashnikov
My Ryobi has 1,170 fl/lbs of breakaway torque. Give me a socket for the center lock and I can guarantee you it will rip it off in seconds.
Using a torque wrench on CL's will be a one-time event as it will damage/destroy the CL nut. Impact torque cannot be used to properly remove/install CL's. Must use a tool that utilizes constant turning torque.
Old Mar 18, 2026 | 01:36 PM
  #54
cutlass476's Avatar
cutlass476
Veteran: Navy
Originally Posted by lpw016
I just don’t like to use the torque wrench to break the tension. It will just fine but I have it set to 95ftlbs and it beeps when I exceed it.
Just personal preference
Most torque wrenches are unidirectional as it relates to torque and their calibration. Meaning, unless your specific torque wrench is calibrated and rated for install and removal, it should never be used to remove a fastener. ONLY for install torque.
Old Mar 18, 2026 | 01:43 PM
  #55
Ikone's Avatar
Ikone
Let me know how much the repair costs are after damaging everything.
PS: you're not supposed to use an impact wrench.
Old Mar 18, 2026 | 01:44 PM
  #56
Ikone's Avatar
Ikone
And the fact you're not supposed to use an impact wrench on the CLs.
Old Mar 18, 2026 | 01:51 PM
  #57
Shogunade's Avatar
Shogunade
Just look at who started this extra 21st chromosome thread.
Old Mar 18, 2026 | 02:52 PM
  #58
3Series's Avatar
3Series
If I recall, the official manual says you need to to torque it to spec, then back it off then re-torque to another spec. You're also supposed to apply special lube, I mean grease.
Just AI the real instructions. These have been discussed for over a decade, lots of experience all over the place
Old Mar 18, 2026 | 02:57 PM
  #59
Ikone's Avatar
Ikone
I don't need AI. I have the manual. This is directly from the owner's manual:
The hard blows of an impact wrench damage the central bolt and the retainer.
The reaction arm of a cordless impact wrench can damage the rims.
When using a cordless impact wrench without a reaction arm, the high torque cannot be countered and there is a risk of tilting.
  • Do not use an impact wrench.
  • Do not use a cordless impact wrench.
